IseWise
Sep 28, 2014Aspirant
ReadyNAS Ultra 4 is slowing down my entire network LAN & WAN
Ive owned a ReadyNAS Ultra 4+ for several years now, with little to no problems, however I'm now having a very strange issue. Every time my NAS is connected to the network, the entire network begi...
muggsy
Jan 09, 2015Aspirant
FiremedicJM wrote: Did not require a complete wipe, Just wiped the OS partition and rebuilt it so it did not wipe data. Tech support can access it if you put it into Tech mode from the boot menu. PM mdgm and I am sure he can help you.
I'm thinking this is what might be causing me massive network issues with my ReadyNAS Pro as well. mdgm, are you able to help me out possibly as well?
OK, my NAS had been hacked...
Similar to this
http://blog.malwaremustdie.org/2014/09/ ... china.html
What able to fix with the help from the comments...
File was being created in /boot/ and /lib/udev/ , called something random...
Pain in my ass.. I thought I had patched my nas to the latest , but missed 4.2.27
