manowell1
Nov 21, 2012Aspirant
ReadyNAS Ultra 4, stuck on boot.
Unit was working as in iSCSI target up until I found it powered off. Only had it set up 4-6 weeks, I have another just like it still working fine. On boot up just get flashing block / underscore ...
manowell1
Dec 29, 2014Aspirant
Can't see boot menu at all, only the flashing block cursor. Have held down the reset button for more then two minutes when powering on, the power light flashed blue then goes to solid blue.
Haven't cracked the case to check the RAM, but if the warranty is void I'm happy to do it if you think it's a good next step.
