manowell1
Nov 21, 2012Aspirant
ReadyNAS Ultra 4, stuck on boot.
Unit was working as in iSCSI target up until I found it powered off. Only had it set up 4-6 weeks, I have another just like it still working fine. On boot up just get flashing block / underscore ...
manowell1
Jan 10, 2015Aspirant
StephenB wrote: In this case mdgm is probably the best resource (and he does happen to work for Netgear).
manowell wrote: I'm asking here because it's out of warranty. If you don't work for Netgear and don't care, I understand. :)
Yes, I purchase two units in 2010, one of them sat on the shelf for two years before I even unboxed it. That's my fault, not Netgears, as well. I agree this is highly unusual, but it is the case in this instance.
The reason for my initial response was the perceived tone (help me or I'll start buying synology :shock: ). It didn't sit quite right. I do hope you get it up and running, despite the long time on the shelf. :)
Sorry if the tone was offputting, I was very frustrated, but most of the frustration was aimed at myself. I was p##sed off that I HAD the USB recoverry link before, but had lost it and couldn't even find it. p##sed off that the unit MAY HAVE BEEN DOA, but I let it sit in the box while support expired. Lesson learned, hopefully.
mdgm got me the links (Thanks, mdgm!), but haven't been able to recover it. Followed that whole thread with varous USB sticks, which worked according to the procedure, but the unit still comes with with a solid LED 4 ("Flash error", I think) and remains bricked.
I've only used Buffalo for one client that insisted, other than that I've only installed NetGear and have had nothing but good results (30+ units) other than this one, which is mine.
