manowell1
Nov 21, 2012Aspirant
ReadyNAS Ultra 4, stuck on boot.
Unit was working as in iSCSI target up until I found it powered off. Only had it set up 4-6 weeks, I have another just like it still working fine. On boot up just get flashing block / underscore ...
mdgm-ntgr
Jan 10, 2015NETGEAR Employee Retired
Did you check the RAM was properly seated as I suggested earlier. If the warranty is expired then I guess that would be a logical next step.
Does the NAS show in RAIDar at all now after trying USB Boot Recovery? If so, what do you see in the Info (far right) column?
