widder18
Sep 07, 2015Aspirant
ReadyNas Ultra 4 stuck on booting (though boot menu is working)
Out of the blue, my ReadyNAS Ultra 4 stopped working. Upon powering off and on again, it is stuck on booting. RAIDar can't find the device, and it does not respond to pings. I can reach the Boot M...
- Sep 15, 2015
Eventually I used the Netgear USB recovery tool (see here for more: http://home.bott.ca/webserver/?p=166) and that finally did the trick.
mdgm-ntgr
Sep 07, 2015NETGEAR Employee Retired
There could be a bad disk.
Can you power down, remove the disks (label order) and connect the disks up to your PC and test them (e.g. test SeaGate disks using SeaTools and WD disks using WD Data Lifeguard Diagnostics)?
- widder18Sep 08, 2015Aspirant
I have tested the disks and they seem fine. I've tried to factory reset the ReadyNAS with each disk separately, but the device still does nothing but boot...
