jokeruk
Feb 28, 2022Aspirant
ReadyNas Ultra 6 continuous reboot
I have a pair of these 6 bay devices and as a rule they have both wored really well. They are running firmware 6.10.67 One of them though has a problem at startup - which seems to have started si...
jokeruk
Mar 04, 2022Aspirant
Ok thanks for that - well I order another one and see if that does the biz
jokeruk
Apr 08, 2022Aspirant
Just as a final update, I swapped the PSU to the one indicated above.
It wasn't a bad fit - once I'd removed a bolt-on outer bracket which I initially thought I'd need to dremmel..
Also the fan surround doesn't poke through the rear hole, rather sits flat inside, and I had to add a moles splitter
However, the reboot problems are resolved - lets see how long it lasts
