SLAM-ER
Mar 09, 2019Aspirant
ReadyNAS Ultra-6 data degraded after firmware update
I have an old ReadyNAS Ultra-6 that I upgraded to Firmware 6.9.5. After the upgrade it shows data degraded. However the data is not degraded, all drives are healthy, I can still access the shares...
- Mar 11, 2019
Hi again
Thanks for posting the disk info. As suspected, disk sda has seen better days. From what I can see in the logs, the disk should be located in bay 1 (the first disk in the NAS). We can see that the disk has some Current Pending Sector errors.
Device: sda Controller: 0 Channel: 0 <<<=== Bay 1 Model: WDC WD60EFRX-68MYMN0 Serial: Firmware: 82.00A82 Class: SATA RPM: 5700 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 33eac74a Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 11 <<<=== Bad sectors on the disk Uncorrectable Sector Count: 0 Temperature: 32 Start/Stop Count: 136 Power-On Hours: 35247 Power Cycle Count: 77 Load Cycle Count: 15929
Pending sectors typically indicates imminent failure of the disk. An Acronis KB, describes the issue particularly well.Current Pending Sector Count S.M.A.R.T. parameter is a critical parameter and indicates the current count of unstable sectors (waiting for remapping). The raw value of this attribute indicates the total number of sectors waiting for remapping. Later, when some of these sectors are read successfully, the value is decreased. If errors still occur when reading some sector, the hard drive will try to restore the data, transfer it to the reserved disk area (spare area) and mark this sector as remapped.
Please also consult your machines's or hard disks documentation.
RecommendationsThis is a critical parameter. Degradation of this parameter may indicate imminent drive failure. Urgent data backup and hardware replacement is recommended.
https://kb.acronis.com/content/9133
It is quite likely that these bad sectors caused the NAS to kick the disk from the one of the data raids. The fact that those sectors appear stuck in "pending" is an indication that the sectors will probably never recover. Without further examination of the logs I'd say you need to replace that disk asap. Note: you must replace with a disk of same size or larger.
Your other disks appear to be healthy, which is good!
Cheers
Hopchen
Mar 11, 2019Prodigy
Hi SLAM-ER
Thanks for posting the mdstat log.
Firstly, let me clarify the behaviour of the NAS with the disk configuration that you have. The NAS will actually raid partitions together, not entire disks. So, when using different size disks as you do, the NAS will make a 2TB partition across all 6 disks and raid those partitions together in a raid 5. That will form one data raid - md126 in this instance.
md126 : active raid5 sdc3[8] sdf3[5] sde3[4] sdd3[3] sdb3[6] 9743324160 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [_UUUUU]
Next the NAS will take the 3 remaining larger disks and make 4TB partitions on each disk and raid those partitions together in a separate data raid. In this case, md127.
md127 : active raid5 sda4[0] sdc4[2] sdb4[1] 7813753856 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
Thereafter, the NAS sticks the two data raids together on the filesystem level in order to make it "one volume". So, what you are seeing with two data raids is perfectly normal when using different sized disks. Sandshark - FYI this will be same configuration whether he factory defaults or not.
With that out of the way, we can see that md126 is degraded. The partition from sda (one of the disks) is missing in this raid.
md126 : active raid5 sdc3[8] sdf3[5] sde3[4] sdd3[3] sdb3[6] <<<=== "sda3" missing as a paticipant here. 9743324160 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/5] [_UUUUU] <<<=== raid notifying you that one disk is out of this raid.
This makes the md126 raid degraded - i.e. non-redundant anymore. Another disk failure will render the entire volume dead at this point so it needs to be addressed. There could be several reasons for the disk going missing in the md126 raid but a firmware update is not a likely suspect. What is more likely is that the "sda" disk has some dodgy sectors on the partition used for the md126 raid and thus the NAS might have kicked it from that raid upon boot.
What is the health of the disks overall? Can you post the output of the disk_info.log (masking any serial numbers for your disks)?
Thanks
