ruudpel
Oct 03, 2014Aspirant
ReadyNAS Ultra 6 expansion
Hello all,
first off, hats off to Netgear for their products and to all of you for creating this amazingly resourceful forum. However, I have two specific questions regarding my setup I haven't been able to find here yet.
Here goes. My setup is ReadyNAS Ultra 6 in X-RAID2 mode with 6 x 2TB discs, giving me 9250GB of space. Probably redudant info, but I'm running on latest firmware and RAIDiator. I'm now at 99% capacity so I'd like to expand.
My first thought was to replace my six 2TB drives with six 3TB drives, but then I had the idea to get four 4TB drives. Costs are approx. the same.
Question 1: is there a good reason to choose either of the two options? What would you choose and why?
Question 2: going from 6 x 2TB to 6 x 3TB is easy. Take one disc out, put a new one in. Let the NAS resync, reboot, etc, and do the other drives the same way. Gonna take a while, but it's easy. What about the 4 x 4TB option though? After replacing the first four 2 TB drives with the four new 4TB drives, can I just pull out the last two 2TB drives safely?
Bonus question: I'm reading a lot about the 16TB capacity limit. Will I encounter this problem with either setup? I'm not willing/able to do a factory reset.
Hope everything is clear and you guys can help me out. if you need any additional info, please ask.
Just in case it's useful: my current drives are Samsung HD204UI's, the new ones will be WD RED's.
With many thanks,
Ruud
With many thanks,
Ruud
- StephenBGuru - Experienced UserYes.
- ruudpelAspirantcool. Looks like I'm finally getting it :) and in this situation, would you recommend Flex-RAID or X-RAID2?
- StephenBGuru - Experienced UserA is the only scenario where flex-raid helps, because it gives you a way to use the last open slot for capacity - which X-RAID2 can't do.
B1,B2,D1,D2 aren't expandable because you've used all the slots.
C is expandable, but X-RAID2 will handle it.
