m021998
Jan 07, 2019Aspirant
ReadyNAS Ultra 6 Plus Failed Motherboard
Hello,
I have an RNDP600U that appears to have a failed motherboard. The device front lights turn on, fans spin, READYNAS is displayed on the front screen, but it never seems to boot past that. ...
- Jan 08, 2019
Hi m021998
Welcome to the Community!
The procedure mdgm is pertaining to is for Data migration to OS 6 which you can get here. This procedure might require Data Recovery contract and Support intervention.
But since you purchased the same unit, your disks provided that they are fine would boot normally with it since they have the same architecture and OS.
We would advised still to initialize setup on the RNDP6000U and update it first before inserting the disks from your older unit,
Hope this helps!
Regards
Marc_V
Jan 08, 2019NETGEAR Employee Retired
Hi m021998
Hope this helps!
Regards
Jan 08, 2019Guru - Experienced User
Yes, you should update the firmware before inserting your disks. You do that by doing a factory install with a single scratch disk (not part of your array). Then update the firmware to whatever was on your original NAS. If you aren't sure, then update it to 4.2.31. Note that the scratch disk will be formated, so anything on it will be lost.
There are two reasons for doing this:
- It confirms that the replacement NAS is working ok, which minimizes any chance of damage to your array.
- If the firmware in the NAS flash memory doesn't match what's on your disks, then the NAS will attempt to install whatever firmware it has onto your disks. While that generally works, it doesn't always (particularly if the replacement has very old firmware). It's best to avoid that risk.
