m021998
Jan 07, 2019Aspirant
ReadyNAS Ultra 6 Plus Failed Motherboard
Hello,
I have an RNDP600U that appears to have a failed motherboard. The device front lights turn on, fans spin, READYNAS is displayed on the front screen, but it never seems to boot past that. ...
- Jan 08, 2019
Hi m021998
Welcome to the Community!
The procedure mdgm is pertaining to is for Data migration to OS 6 which you can get here. This procedure might require Data Recovery contract and Support intervention.
But since you purchased the same unit, your disks provided that they are fine would boot normally with it since they have the same architecture and OS.
We would advised still to initialize setup on the RNDP6000U and update it first before inserting the disks from your older unit,
Hope this helps!
Regards
Marc_V
Jan 08, 2019NETGEAR Employee Retired
Hi m021998
Hope this helps!
Regards
m021998
Jan 26, 2019Aspirant
I received another ultra 6 plus from ebay, put in a single temporary drive, factory reset it, updated the firmware, then put in all 6 disks from my original unit and my iscis luns were available and online.
thanks.
