rdelassalas
Oct 31, 2019Aspirant
ReadyNAS Ultra 6 Plus
I am running the latest version of RAIDiator and I would like to upgrade this NAS box to the very latest OS so I can take advange of new and improved apps. I was reading some poting in the community ...
Campus
Nov 05, 2019Luminary
Keep in mind that version 6 is highly unstable on old devices. I have multiples Pro 6 boxes which disappear from the network from time to time (especially when doing a rsync backup) and have to be cold-reset to be available again.
Sandshark
Nov 05, 2019Sensei
Campus wrote:Keep in mind that version 6 is highly unstable on old devices. I have multiples Pro 6 boxes which disappear from the network from time to time (especially when doing a rsync backup) and have to be cold-reset to be available again.
I 100% disagree with that statement. Providing you have upgraded the memory to at least 2GB, OS6 can be very stable on older hardware, and has been for me. I have had it successfully running on Pro2, Ultra4, Ultra4Plus, Pro6, Ultra6, RN4200V2, and RD5200 systems. I'm down to fewer only for consolidation, since I have a place for rack-mount systems, not because of problems with any of them.
Of course, if an aging system already has problems, then OS6 might make them worse with more demand on it.
If the Ultra6Plus has the normal 1.8GHz Pentium, then upgrading the processor can also make it snappier. But check first, as I had one that came with the same 2.6GHz one as the Pro6.
Although the Ultra6Plus/Pro6 motherboard does not utilize dual-channel memory, I recommend you still upgrade in pairs, not just throw in another stick of potentially diffferent size and timing. I have always stuck with CL5 memory, too, as that's what came with them (at least in the early years).
- CampusNov 05, 2019Luminary
Then you are lucky. I have multiple boxes with maxed memory, fastest possible cpu which never had any issues with OS4 which reproducible hang when running rsync backups from remote rsync servers. I am also not the only one as others reported the same issue here in the forum in the past, like here: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-Pro-6-has-become-unstable-and-regularly-hangs/td-p/1517936
- StephenBNov 06, 2019Guru - Experienced User
Campus wrote:
Then you are lucky.
I haven't converted my own Pro-6, but based on posts here I'd say that you (and some others) were unlucky. Most folks haven't run into any issues with the conversion. Some have had some minor issues with temperature and fan status. One or two bricked their NAS (likely some underlying issue with the flash memory in their NAS).
There are some risks. But if the process succeeds and you don't like the results, the conversion can also be reversed.
FWIW, my Pro-6 (which backs up my RN526x) will need a factory reset to expand it's volume. If I'm still using it when I need to expand it (or need to reset it for another reason) I will convert it to OS-6.
