jrakoczi
Sep 09, 2015Aspirant
readynas usb flash recovery images
Hi
Anybody knows where can I download readynas_usb_flash_recovery_4.1.4.img or previous versions?
I only found 4.1.8 and 4.1.12, but i need earlier version for v1 readynas.
Thanks
- mdgm-ntgrNETGEAR Employee Retired
What do you need such an old version for?
- BrianL2NETGEAR Employee Retired
Hi jrakoczi,
I apologize. The link I have attached is for the RAIDiator version 4.1.4. Let me try to dig up if we have a copy of the USB Flash 4.1.4.img.
Kind regards,
BrianL
NETGEAR Community- jrakocziAspirant
Hi Brian
You are right i would need the ReadyNAS_USB_Flash_Recovery-4.1.14.img file. I just cannot find it.
I have an older rnd 4000 v1 (readynas nv) and the update from the regular firmware zip file is always fail (unknown error), but i can do the usb flash update and right after the os overwrite. Right now i am on 4.1.12 version.
Thanks for your help
Jozsef
