Ramiro
Jan 29, 2017Aspirant
ReadyNAS VN+ RND4000 boot problem
I usualy keep my NAS shut down only turning it on when I need to do backups or access files. Last time I tried to turn it on it froze on 'booting....'. In a probably wrong move i decided the b...
Jan 29, 2017Guru - Experienced User
Are you comfortable with SSH?
Ramiro
I have used in the the past, and I know some basic linux, but I the problem is how to get ssh access without a proper boot.
- StephenBJan 30, 2017Guru - Experienced User
Well, you can use tech support mode and telnet in.
The telnet user/pass is root/infr8ntdebug
From there you'd mount the OS partition using
# start_raid.sh
# mount /dev/md0 /sysroot- RamiroJan 30, 2017Aspirant
Many thanks for your help.
Unfortunatly the unit also hangs on 'Tech Support Please wait....'.
I decided to remove all disks, put in a blank one and start the unit.
All went well. The system was up and running after OS installed and partition created. Installed the ssh enabler.
Accessed the dashboard and loged in with ssh.
After putting back the previous 4 disk array, no normal boot, no thech boot.
Maybe test the disks with vendor tools? Lifeguard for western digital, Seatools for seagate.
