Ramiro
Jan 29, 2017Aspirant
ReadyNAS VN+ RND4000 boot problem
I usualy keep my NAS shut down only turning it on when I need to do backups or access files. Last time I tried to turn it on it froze on 'booting....'. In a probably wrong move i decided the b...
Jan 30, 2017Guru - Experienced User
Well, you can use tech support mode and telnet in.
The telnet user/pass is root/infr8ntdebug
From there you'd mount the OS partition using
# start_raid.sh
# mount /dev/md0 /sysroot
Ramiro
Jan 30, 2017Aspirant
Many thanks for your help.
Unfortunatly the unit also hangs on 'Tech Support Please wait....'.
I decided to remove all disks, put in a blank one and start the unit.
All went well. The system was up and running after OS installed and partition created. Installed the ssh enabler.
Accessed the dashboard and loged in with ssh.
After putting back the previous 4 disk array, no normal boot, no thech boot.
- StephenBJan 30, 2017Guru - Experienced User
Maybe test the disks with vendor tools? Lifeguard for western digital, Seatools for seagate.
- RamiroFeb 04, 2017Aspirant
Anyway, made some tests using seatools and htunepro. Seatool passed all tests.
HDtune 'error scan' reported some damadged block errors on disk 2. As they were getting too many I decided to abort the test.
Tested the other 3, they cleared the tests. Then put disk 2 back in and it also passed.I ended up running the hdtune 'error test' for all 4 disks 2 times, also logged smart statistics after the tests.
I have attached them to this post, if anyone cares to have a look.Don't really know what to do at this point should try to boot the NAS again?
Should I attempt to the start the NAS with 3 disks, say removing disk 2, or would that be a bad idea?Spoiler-----------
DISK1/TEST2
-----------HD Tune Pro: SAMSUNG HD103UJ Error Scan
Scanned data : 999 gB
Damaged Blocks : 0.0 %
Elapsed Time : 3:16:04
HD Tune Pro: SAMSUNG HD103UJ HealthID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 100 51 0 ok
(03) Spin Up Time 69 69 11 10180 ok
(04) Start/Stop Count 98 98 0 2196 ok
(05) Reallocated Sector Count 100 100 10 0 ok
(07) Seek Error Rate 100 100 51 0 ok
(08) Seek Time Performance 100 100 15 10162 ok
(09) Power On Hours Count 96 96 0 22686 ok
(0A) Spin Retry Count 100 100 51 0 ok
(0B) Calibration Retry Count 100 100 0 0 ok
(0C) Power Cycle Count 100 100 0 481 ok
(0D) Soft Read Error Rate 100 100 0 0 ok
(B7) SATA Downshift Count 100 100 0 0 ok
(B8) End To End Error Detection 100 100 0 0 ok
(BB) Uncorrectable Error Count 100 100 0 0 ok
(BC) Command Timeout 100 100 0 0 ok
(BE) Airflow Temperature 64 50 0 604962852 ok
(C2) Temperature 59 50 0 705626153 ok
(C3) Hardware ECC Recovered 100 100 0 47887589 ok
(C4) Reallocated Event Count 100 100 0 0 ok
(C5) Current Pending Sector 100 100 0 0 ok
(C6) Offline Uncorrectable 100 100 0 0 ok
(C7) Interface CRC Error Count 100 100 0 0 ok
(C8) Write Error Rate 100 100 0 0 ok
(C9) Soft Read Error Rate 100 100 0 0 okHealth Status : ok
DISK2/TEST1
Scanned data : 236 gB
Damaged Blocks : 1.0 %
Elapsed Time : 4:29:48
1 Error at 189794 MB (LBA 388698464)
2 Error at 189795 MB (LBA 388701408)
3 Error at 189809 MB (LBA 388729568)
4 Error at 225342 MB (LBA 461502400)
5 Error at 225347 MB (LBA 461510848)
6 Error at 225349 MB (LBA 461516224)
7 Error at 225350 MB (LBA 461518400)
8 Error at 225358 MB (LBA 461534656)
9 Error at 225360 MB (LBA 461537344)
10 Error at 225362 MB (LBA 461542464)
11 Error at 225362 MB (LBA 461543232)
12 Error at 225364 MB (LBA 461546304)
13 Error at 225365 MB (LBA 461548608)
14 Error at 225365 MB (LBA 461549504)
15 Error at 225366 MB (LBA 461550400)
16 Error at 225368 MB (LBA 461553728)
17 Error at 225369 MB (LBA 461556672)
18 Error at 225371 MB (LBA 461560512)
19 Error at 225372 MB (LBA 461563200)
20 Error at 225373 MB (LBA 461564608)
21 Error at 225373 MB (LBA 461565632)
22 Error at 225377 MB (LBA 461572544)
23 Error at 225378 MB (LBA 461574720)
24 Error at 225381 MB (LBA 461581888)
25 Error at 225383 MB (LBA 461584576)
DISK2/TEST2
Elapsed Time : 3:04:08
(03) Spin Up Time 68 68 11 10390 ok
(04) Start/Stop Count 98 98 0 2288 ok
(08) Seek Time Performance 100 100 15 11196 ok
(09) Power On Hours Count 95 95 0 22735 ok
(0C) Power Cycle Count 100 100 0 480 ok
(BE) Airflow Temperature 64 54 0 638451748 ok
(C2) Temperature 64 53 0 705560612 ok
(C3) Hardware ECC Recovered 100 100 0 68510758 ok
(C7) Interface CRC Error Count 100 100 0 487 attention
DISK3/TEST2
Elapsed Time : 3:08:14
(03) Spin Up Time 69 69 11 10170 ok
(04) Start/Stop Count 98 98 0 2327 ok
(08) Seek Time Performance 100 100 15 9987 ok
(09) Power On Hours Count 96 96 0 22712 ok
(0B) Calibration Retry Count 100 100 0 1 warning
(BE) Airflow Temperature 66 53 0 571342882 ok
(C2) Temperature 62 53 0 688783398 ok
(C3) Hardware ECC Recovered 100 100 0 82202324 ok
(C9) Soft Read Error Rate 100 100 0 0 okHealth Status : warning
DISK4/TEST2
Elapsed Time : 3:23:13
(03) Spin Up Time 68 68 11 10310 ok
(04) Start/Stop Count 98 98 0 2342 ok
(08) Seek Time Performance 100 100 15 10814 ok
(09) Power On Hours Count 95 95 0 22788 ok
(0C) Power Cycle Count 100 100 0 488 ok
(BE) Airflow Temperature 63 52 0 621674533 ok
(C2) Temperature 61 51 0 688783399 ok
(C3) Hardware ECC Recovered 100 100 0 64042377 ok
Regards.
- RamiroFeb 06, 2017Aspirant
I decided to put the disks back in and start the system.
It finaly booted and everything is looking nomal, as if nothing happened.
Thanks everyone for helping.
Best regards.
Ramiro.
