augur
Sep 22, 2018Apprentice
ReadyNAS with newest OS 6.9.4 hangs - no watchdogs
Hi,
I am using a ReadyNAS Pro 4 with Resilio Sync and sometimes it simply stopps working. I saw some watchdogs threads in SSH and thinking of why the watchdogs does not restart the NAS? Does an...
Sep 22, 2018Guru - Experienced User
FWIW, your model tag is for the NV+, not the Pro-4.
Not something I would want. One reason is that it would make troubleshooting more difficult.
augur wrote:
I am using a ReadyNAS Pro 4 with Resilio Sync and sometimes it simply stops working.
By "it", do you mean Resilio Sync, or do you mean the ReadyNAS itself?
- augurSep 22, 2018Apprentice
Hi,
did not find Pro 4 Tag but my NAS is an RDN4000 if I am correct. So I decided for this tag.
The NAS is located in a different city and a hard reset is not that easy. It hang complety and is not reachable through SSH or something else. Even the LCD is locked so I have to do a hard shutdown pressing the power button for a while.
Cheers,
Nils
- StephenBSep 22, 2018Guru - Experienced User
augur wrote:did not find Pro 4 Tag but my NAS is an RDN4000 if I am correct. So I decided for this tag.
It's best to leave the tag out if you don't find your NAS. The pro-4 would be the RNDP4000, and the tag is in there (I put it my reply). The RND4000 is quite different (and can't run OS 6).
Ok. so it's the NAS hanging. Do you have any other apps running on it? Have you looked in the log zip file?
