Superfly's avatar
Superfly
ReadyNAS424 has reset after a power cut
Hi there,
I took the plunge back in November and purhased a ReadyNAS424.  I put a spare HDD into it to get to learn how it operated and after 2 days, I had managed to get it working.  Over the festive period while I was away there was a power cut in my area and now the unit has lost its identity, does not recognise the HDD still inside and has lost connection with the Insight and Cloud apps.  While it was still working I did manage to get the firmware updated to 6.10.4.  I have tried rebooting the unit to no avail.  I don't believe in this era that something like this should lose all its memory from a power cut.  I reckon it'll need a factory reset to get it working again, which I had to do over the 2 days initially setting it up in November. I don't mind resetting the unit to get it working again but I want to avoid the memory and identity loss from happening again.  Is there something I did not do right during or after the setup?  Is there a chance the unit could be faulty?  What can I do once I've reset it to prevent this from reoccuring?
Thanks so much in avance for any advice.
Liam
  • With a single drive you do, of course, have no data latency.  But that may not have helped.  A power cut in the middle of a critical file system operation can render the volume inaccessible, even with RAID.  That is why an UPS is always recommended with a NAS, and that UPS needs to be monitored by the NAS to initiate a clean power-down before the battery runs out.
  • StephenB's avatar
    What do you mean by "lost its identity"???
    • Superfly's avatar
      Superfly
      Hi guys,
      Thanks very much for your replies. It seems then that there was no fault with the set up or with the unit itself but just how it operates. A power cut leads to the aforementioned problem.
      I had named the drive and that showed in the display on the front. It now calls itself “nas-45-...”. I think once I get it reset and working again, I’ll invest in a UPS. How does that connect into the system? Directly or into the WiFi router via Ethernet?
      Thanks again
      • StephenB's avatar
        Actually usually not.  But it can.
        Obviously you'd named the NAS, not the drive.  Going back to the default name suggests that the NAS can't boot from the OS partition (or that the configuration files on the OS partition have been corrupted).  This is unusual - you might be able to see more useful information from RAIDar: https://kb.netgear.com/20684/ReadyNAS-Downloads
        But if the NAS isn't detecting the disk, then it probably would go back to the default name in the boot loader.
        I suggest testing the disk in a Windows PC with vendor tools - if there was any power surge related to the power failure, the drive might be damaged.  Use Lifeguard for WD disks, and Seatools for Seagate - and run the extended test, not just the short one (which really is more of a confidence test).
        If the disk passes the test, then the NAS itself might have been damaged.  If that's the case, you can contact paid tech support, and ask for an RMA.  FWIW, I wouldn't volunteer the power-loss information.
        Normally it is connected via a USB cable to the NAS.  The toolkit in the NAS is NUT (network ups tools).  They have some information o compatibility on their site. https://networkupstools.org/
        APC is a popular brand, I use CyberPower which works with my OS-6 systems.
ProSupport for Business
