mctubster
Mar 31, 2016Tutor
readynasd errors
Hi, My ReadyNAS is under high CPU load as it is spewing the following error into the logs "Mar 31 21:52:03 nas readynasd[2344]: read() ==> len=-1, errno=19" Any thoughts? Cheers
Mar 31, 2016Guru - Experienced User
I'd engage support right away (you should have lifetime chat support if this was purchased from an authorized reseller after June 1, 2014). http://www.netgear.com/support/contact.aspx?cid=gwmng
- JennCMar 31, 2016NETGEAR Employee Retired
Hello mctubster,
What is the current firmware version and model number? What are the apps running and services enabled?
- mctubsterApr 02, 2016Tutor
Hi,
ReadyNAS314 running 6.4.1
The filesystem and array seemed fine, it is a bit of a random type of error and I assume readynasd is the admin interface? Anyway I rebooted and the error stopped.
Regards
Steve
