mctubster
Mar 31, 2016Tutor
readynasd errors
Hi, My ReadyNAS is under high CPU load as it is spewing the following error into the logs "Mar 31 21:52:03 nas readynasd[2344]: read() ==> len=-1, errno=19" Any thoughts? Cheers
mctubster
Apr 05, 2016Tutor
Hi,
I had a look around when / hit 90%+ and cleaned up some core files.
At 75% now, mostly gcc, java8, python2.6/2.7, mono,
Ah just found and cleaned up a squeezeboxserver backup, so now at 70%. Is there a percent free I should aim for? I guess I could move Java8 and soft link it?
Cheers
Cheers
- mdgm-ntgrApr 05, 2016NETGEAR Employee Retired
I would think on most systems the root volume usage should be under 50% if things are stored where they should be.
