garethjjones
Apr 27, 2016Aspirant
ReadyNasUltra 4 dead #26795494
One of the disk was showing increasing Smart errors, so I ordered a replacement disk (ST3000VN000) -to replace the failing disk. No big deal I thought.
I had assumed that the failing disk was d...
- Apr 29, 2016
Netgear support managed to rebuild the array remotely, using mdadm and then mount the array.
Powered off, removed the bad disk 1 and rebooted with only disk 2,3 and 4 and then could access with fontview.
Put the new disk in disk1 slot, and the raid array has re-synched and we're now back online, all data intact (AFAIK).
Now looking at implementing crashplan on the Ultra4 - though not sure how long it would take to upload data!
Apr 27, 2016Guru - Experienced User
If you have a backup (or are ok with losing data) then I'd suggest doing a factory reset, which will do a fresh factory install.
You'll need to reinstall any add-ons, and reconfigure the NAS, and restore the NAS data. This will take a while, but will get everything back to a known/clean slate.
Another option is to contract with Netgear. With per-incident support they might be able to remount the volume. Data Recovery would be its own (and more expensive) contract.
garethjjones
Not all the data is backed up - that's the issue - so I'm not really happy with losing the data.
I've created a support case 26795494, and uploaded the logs - though if anyone else has any ideas I'm happy to hear them.
It's pretty difficult to find out how much this service costs - only by searching the forums, and then it's "about"
