sstillwell
May 17, 2019Tutor
ReadyTIER log message...problem?
I've discussed elsewhere the setup of ReadyTIER on my ReadyNAS Pro unit, but I'm seeing some odd behavior in the logs and not sure what it implies...hoping someone has seen it before.
I've got ...
yxue
May 20, 2019NETGEAR Expert
Is your migration is doing,, or your disk group is almost full? so another migration job fail to start
sstillwell
May 20, 2019Tutor
I don't think that the group is filling up before the migration finishes...but that sure is a possibility. I can try lowering the percentage from 90% down to 75% or even 50%. The SSD tier is a pair of 512GB Samsung 860 PRO. I've set it to twice a week or when 70% is reached...we'll see if that improves matters.
