sstillwell
May 17, 2019Tutor
ReadyTIER log message...problem?
I've discussed elsewhere the setup of ReadyTIER on my ReadyNAS Pro unit, but I'm seeing some odd behavior in the logs and not sure what it implies...hoping someone has seen it before.
I've got ...
Icewaterhot
May 28, 2019NETGEAR Employee Retired
Hello sstillwell,
Could you please enable SDM and PM the code? We will take a look this issue.
https://kb.netgear.com/000053266/ReadyNAS-OS-6-Enabling-Secure-Diagnostics-Mode
sstillwell
May 28, 2019Tutor
I can do that if you want, but you should know that I've already destroyed and re-created the volume with just the 4 x 8 TB WD Red drives, let it resync, then ran a full disk check against it before starting to cautiously use it again. If any logs are stored on nonvolatile storage rather than the disks, I'd be happy to let you see it, but I'm afraid there's not much there to see now.
