sstillwell
May 17, 2019Tutor
ReadyTIER log message...problem?
I've discussed elsewhere the setup of ReadyTIER on my ReadyNAS Pro unit, but I'm seeing some odd behavior in the logs and not sure what it implies...hoping someone has seen it before.
I've got ...
sstillwell
May 28, 2019Tutor
Ah, I guess at least the journalctl log goes back before the crash, so you may be able to get what you need. I've sent you the port infirmation via PM.
sstillwell
Jun 06, 2019Tutor
...and after recreating a brand-new volume with only the spinning disks in RAID5, allowing it to fully sync and running successful disk checks on all disks...
It went read-only and then completely down again. This time I may not be able to get it back. Mounting it says there's a bad superblock, but btrfs rescue super-recover says "All supers are valid, no need to recover". Mounting with -o recovery,nospace_cache,clear_cache says "wrong fs type, bad option, bad superblock on /dev/md127. btrfs rescue zero-log says "ERROR: incorrect offsets 24187 2658730369", btrfs check /dev/md127 says the same thing.
Whatever data I manage to recover, this unit is getting powered down and is going on a shelf or into the recycle bin. I can't afford the time this is costing me, not to mention the data I'm probably going to lose...terabytes of archival material that cannot be replaced. I'm angry enough that I want to use language that would not be approved here. Note: these drives are very new, and check out 100% okay...according to your own diagnostics. Maybe I shouldn't trust those either, eh?
If anyone from Netgear wants to log in and look at it, I will turn on remote diagnostics while I still have it powered up, but note that this won't be for long...only until the point that I give up trying to get data back. Once I'm done with that, it's all over.
