hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
mdgm-ntgr
Aug 06, 2012NETGEAR Employee Retired
By default it will attempt to receive an IP address via DHCP. If it can't receive an IP address then it will use the I.P. address you mentioned.
Does it still show "Requesting IP ...." on the LCD?
