hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
hegnerd
Yes it still says "Requesting IP ..."
I booted it with no cable plugged into the NIC and it still says it.
Any ideas ??
Any ideas ??
