hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
hegnerd
How is using just one disk going to change the fact that the device thinks it setup to use DHCP?
Is there no other way to get into the device?
