hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
mdgm-ntgr
Aug 06, 2012NETGEAR Employee Retired
It won't change that but as the disks have compatibility issues it's possible that using a single disk will allow it to pickup an IP address (or realise it hasn't found one and go to the I.P. address you mentioned).
If that doesn't work I do have other suggestions at least one of which should resolve the problem but best to try this first.
