hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
mdgm-ntgr
Aug 06, 2012NETGEAR Employee Retired
After your successful update from 4.1.6 to newer firmware please do a factory default (wipes all data, settings, everything). Without 4k sector partition alignment you will likely have poor write performance with your disks. Do note there is an ownership issue on 4.1.9 so you may prefer to run 4.1.8 or 4.1.10 beta.
