hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
hegnerd
I'll try to downgrade to 4.1.8.
Is there a way to 4k sector partition alignment with 4.1.8? If not will we be stuck with poor write performance?
