hegnerd
Aug 06, 2012Aspirant
ReasyNAS looses connectivity ....
I have a ReadyNas NV+. I performed a factory reset using the pin hole slot on the back of the device. Now when the device boots i can ping it momentarily then the message "Requesting IP ...." appears ...
mdgm-ntgr
Aug 06, 2012NETGEAR Employee Retired
An issue where ownership of files is transferred to the wrong user which would prevent access to read files or make changes. Data would still be left intact.
You just need to do a factory default after updating successfully to RAIDiator 4.1.7 or newer. Can do it on any of 4.1.7, 4.1.8, 4.1.9 etc (personally I wouldn't do it on 4.1.9 due to the ownership issue mentioned above).
