Dewdman42
Jan 17, 2026Virtuoso
Recommended Approach for upgrading drive
I have to replace a drive with some early smartctl errors, looking for advice on how to best proceed. I am going to be upgrading the size and also moving volumes round between a couple of drives tha...
Sandshark
Jan 18, 2026Sensei
You cannot have two volumes of the same name nor is it easy to change a volume name (see Changing-the-volume-name-on-an-os6-based-nas if you really want to do it). To get what you want, you'll need to use your backup to restore volume contents after you DESTROY and then replace each or an intermediary drive/volume. Since using an intermediary drive entails two copy operations, NAS-to-NAS copy from the backup may not be a lot slower.
To use an intermediary drive:
Add Volume3 in the empty slot.
Copy contents of Volume2 to Volume 3.
DESTROY Volume2.
Add new Volume2.
Copy contents from Volume3 to Volume2.
Delete contents of Volume 3.
Copy contents of Volume` to Volume 3.
DESTROY Volume`.
Add new Volume1.
Copy contents from Volume3 to Volume1.
You could use an external drive as intermediary instead, but it will take more time. Restore from backup is probably at least as fast.
If the drive in slot 1 isn't the primary volume (contains home folders and apps), then there is more to do. See How-to-save-your-apps-when-destroying-your-main-volume-OS6. If that volume was the first drive you put in, it should be primary. Otherwise, one of the others is. This extra step is needed if you use home folders or have apps installed, regardless of the method used to copy the volume contents.
FYI, the SSD with the OS is probably doing less than you think. The OS is in RAID1 on all drives, so having one with the OS only doesn't speed up OS access. It will speed up home folder access and app access if it's the primary drive.
Dewdman42
Jan 18, 2026Virtuoso
I was afraid of that. I will just restore from the backup NAS, that is way more straight forward.
When I pull a drive out (in order to create a new volume of the same name), do I need to do anything else before or after pulling it to actually remove the volume completely, in order to create a new volume of the same name? Or just pull it and its gone? Does it need to be "deleted" in some way through front view or otherwise?
The reason I arranged things the way I did with an SSD for the OS was not for speed per say, it just happened to be a drive I had laying around. That is indeed the drive with the OS. the main reason I did it like that is so that the OS drive is completely separated from my data volumes, I can change my various data volumes at will without affecting my OS installation. So I don't think I should have to move any apps or do anything other then setup the new volumes and restore to them. worst case if the OS drive fails, I'll deal with it, not the end of the world, but again it will be separated from my data volumes.
I realize my configuration is non standard. I am trying to avoid raid5 more than anything. Its possible I will mirror one of the volumes later. Anyway this is how I chose to do it this time. Perhaps it would be ok in the future to have two mirrored volumes, in which case the OS would be on one of those mirrored arrays and the other array would be only a data volume, something like that. But I more or less just decided I don't want to deal with even mirroring and I'm relying on my NAS backup and offsite backup for now.
