BJB
Jul 05, 2021Aspirant
Recommended backup device for an RN424
I am considering backing up my RN424 which has 2 10TB drives and 2 12TB Seagate NAS drives to another device. Preferably offsite but perhaps on same network. I certainly do not need speed of access ...
Sandshark
Jul 05, 2021Sensei
Unfortunately, ReadyNAS stocks are very low, so it's more a question of what you can find than cost effectiveness. And when you can find them, they are pricey right now. A non-ReadyNAS solution would certainly work. But a ReadyNAS solution, assuming the same number of drives in each and both running OS6, has the added advantage of being able to move the drives from one to the other if the hardware dies.
Used is an option, including a legacy unit converted to run OS6. But you get no warranty support, and it's hard to know the previous life cycle of the NAS. Other than power supplies, which can be replaced, I've found them to be reliable for years. But it's still risky.
How many drives? I personally still choose to use RAID for my backups. But if it's truly backup (another copy of everything exists), not archival, then you coulod go without at a greater risk of having to start over in the case of a drive failure.
As far as implementing the backup, I recommend using a VPN. That would be independent of what device you use. I personally choose ZeroTier, but OpenVPN, especially if implemented in your routers, is another option.
- StephenBJul 05, 2021Guru - Experienced User
As far as jbod goes, I think you could go with a 2-bay NAS with two 16 TB Seagate Ironwolf drives. That would run you maybe $1500.
Matching your current drives (RAID) in a 4-bay NAS would probably be about $1800. (I used QNAP for rough pricing, since ReadyNAS are so expensive right now. I've never owned one, so please don't view that as a recommendation).
For a ~$300 difference, I'd go with the four bay myself, as it would make volume expansion much easier.
- BJBJul 05, 2021Aspirant
Thanks. Wow, I've Been Away For A While! I Assume Sourcing Issues Are Hurting Production And Driving Up Readynas Prices Or Is Something Else Going On ?
I actually Also Have An Old Rn104 That Was My Production Nas Before The RN424. If I Pulled And Saved The Old 4 Drives In Case Of Some Future Need And popped In New Ones Would That Work?
I Just Had To Show How Android Typing Is Working By Not Fixing Each First letter Of Each Word!đ
Thanks,
BJB
- StephenBJul 06, 2021Guru - Experienced User
Netgear hasn't said, but there are some folks thinking that they are exiting the NAS business. Though it is possible that it is also linked to supply chain problems.
