medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
medimus
Mar 10, 2010Aspirant
Thank you very much for your support, but during the time my recycle bin was filled up I have used different configurations, including leaving it on overnight. I don't see why this would be a solution and - as I have said - I have now decided that I don't need the recycle bin, so I have left it off and I don't intend to turn it on again. But I'm very impressed with the Netgear support, it's not common to have someone trying to solve computer problems like you have done! :D
