medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
ewok
Mar 12, 2010NETGEAR Expert
We did find a minor bug in the Recycle Bin cleanup script that could cause more space to be used than expected, but I'm not sure it would result in as large of a difference as you saw. If you decide to enable Recycle Bin in the future and still see a problem, let me know.
