medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
medimus
Mar 14, 2010Aspirant
I deleted the whole folder (first all files, then I waited 24 hours, then I deleted the folder itself (I had turned off the recycle bin function before)). I can't see any risk doing this, at least if you want to disable the bin. But your message seems to be another proof that something is wrong in the cleanup script.
