medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
philb1
Jun 07, 2010Aspirant
Hi,
Is there an answer to the problem reported by medimus above? I have exactly the same problem with the disk filling up because the recycle bin files are never deleted. I have tried all the suggestions in the post but nothing works.
Any help would be appreciated?
Thanks in advance
Phil
Thanks in advance
Phil
