medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
ewok
Oct 12, 2010NETGEAR Expert
Can you try leaving it on for a couple of days and see if the Recycle Bin gets cleared?
