medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
jerock
Dec 11, 2010Aspirant
I have experienced this same problem with my RadyNas NV+. I have the recycle bin set to 4000mb & 10 days & received the message my NAS was 87% full. I had 800 gb in the recycle bin. of deleted backup files. I did a firmware upgrade after this message so not sure if that will help. I just deleted all files in the recycle bin.
