medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
jjenson1
Oct 27, 2011Aspirant
Hi,
Is there an answer to the problem reported by everyone above? I have exactly the same problem with the disk filling up because the recycle bin files are never deleted. I have tried all the suggestions in the post but nothing works.
CLEARLY there is bug here, can this be fixed since it's been going on for over a year?
Any help would be appreciated?
Thanks in advance
Jeff
Thanks in advance
Jeff
