medimus
Mar 02, 2010Aspirant
Recycle bin fills up my ReadyNAS
I use Radiator 1.4.6 with my ReadyNAS Duo. About two months ago I enabled the Recycle bin for my CIFS share "Backup", with options "Remove files older than: 10 days" and "Limit Recycle Bin to: 200 Mb"...
jerock
Nov 01, 2011Aspirant
OK I've tried everything suggested on this forum and had to disable the trash bin because it just doesn't work as it's supposed to. So I'll play.
Firmware 4.1.8 [1.00a043] / I had 4gb for the recycle bin when I used it. I have a total pf 2771 GB with 1483 GB used.
