BikeHelmet
Mar 05, 2011Aspirant
Recycle Bin Size Limit / Behaviour?
Hello all, Not sure if this is the right section. Anyway, I was wondering what the size limit is for the per-share recycle bin? The limit seems to be 5 characters, so "99999" seems to be the max? H...
ewok
Mar 09, 2011NETGEAR Expert
Setting it to 0 should disable the size limit. The Recycle Bin does not take into consideration the amount of free space on the volume when cleaning up, it only uses the settings in the Recycle Bin section.
