kslagerman
Aug 03, 2016Aspirant
Redirect Default Web Access Not Working 6.5.1
I'm not sure if this is a configuration or an OS issue, but I noticed today that all default or unspecified HTTP traffic to my ReadyNAS 102 is going straight to /admin. (example, http://mydomain/ go...
bedlam1
Aug 03, 2016Prodigy
Try ticking HTTP Admin and try again
kslagerman
Thanks. Just tried that as you recommended and no luck. Only option is still "None Selected".
- JennCAug 03, 2016NETGEAR Employee Retired
Hello kslagerman,
Could you try checking the share's permission for HTTP if that is enabled?
- kslagermanAug 03, 2016Aspirant
HTTP is enabled for all share that require it and they are accessible from a web browser. I can access the shares fine if i go to http://mydomain/<share name> but I want to be able to redirect unspecified request to a specific share. Specifically, if i got to http://mydomain/ is redirects to the admin login screen. The Redirect Default Web Access option in HTTP settings use to allow this functionality, but now it only shows "None selected"t as an option.
This has worked for years and now it no longer works.
- StephenBAug 03, 2016Guru - Experienced User
It works on my RN102. http admin is off, and I see shares listed in the pulldown. I chose one, and http://nasipaddress was redirected to the share.
Are the shares enabled for http?
