RMcP1
Oct 19, 2015Aspirant
registering node
Hello I have recently installed the ReadyNAS Remote Windows App Beta(1.7.6.27) having upgraded to Windows 10 and been unable to login in remotely. When I try to login remotely to our ReadyNas Ultra2...
BrianL2
Oct 20, 2015NETGEAR Employee Retired
Hi RMcP1,
Welcome to the community!
It appears that the problem is specific on this PC. Did you use a single ReadyNAS remote ID on your test on your iPad and secondary laptop? Also try to check if there's a firewall or a security software on this pc that may have blocked the ReadyNAS remote app to connect to server. Lastly, you want to run windows compatibility (Windows 7 or 8) prior the installation of the ReadyNAS remote app and see if it helps.
Kind regards,
BrianL
NETGEAR Community Team
RMcP1
Nov 06, 2015Aspirant
Hi BrainL
Not sure what you mean by a 'single ReadyNAS remote it' - I just installed the app and logged in and it worked whereas it won't on this laptop!
From what I can see, the logging on is not being blocked by any firewall as ReadyNAS is allowed through.
I have also run windows compatability again and tried to reinstall, and found myself in exactly the sma eposition again as registering node...
Any other ideas?
Thanks
Richard
