lovesky
Nov 10, 2018Aspirant
Reinstall OS after Xpenology
Hello, everything's okay I bought, second hand, a NAS model Readynas RNDU2000. However, the seller had installed on Xpenology. Before selling his NAS, he remove Xpenology and told me that I need j...
JohnCM_S
Nov 10, 2018NETGEAR Employee Retired
Hi lovesky,
Welcome to the Community!
You may try accessing the boot menu and then select the OS reinstall there. You may check this article on how to access the boot menu and select the OS reinstall.
lovesky
Hello JohnCM_S,
It doesn't work :'(
In step 4 : "Continue to press the Reset button until the Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED illuminate." <--- I've only the Power button LED on , the others no.
I've try lot of time but without success.
Always, only the Power button LED is lighting
- Jul 15, 2018Retired_Member
