lovesky
Nov 10, 2018Aspirant
Reinstall OS after Xpenology
Hello, everything's okay I bought, second hand, a NAS model Readynas RNDU2000. However, the seller had installed on Xpenology. Before selling his NAS, he remove Xpenology and told me that I need j...
lovesky
Hello JohnCM_S,
It doesn't work :'(
In step 4 : "Continue to press the Reset button until the Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED illuminate." <--- I've only the Power button LED on , the others no.
I've try lot of time but without success.
Always, only the Power button LED is lighting
Nov 11, 2018Guru - Experienced User
Try zeroing one of the disks (WDC's Lifeguard and Seagate's Seatools programs will do this). Then put that zeroed disk into the NAS by itself, and power it on. If the USB flash wasn't modified by the seller, the system should do a factory install.
If that fails, you could try doing a USB recovery. Or maybe contact the seller - they really should have reinstalled the Netgear OS for you.
- loveskyNov 12, 2018Aspirant
Hello StephenB,
It doesn't work too :'(
Nothing happend when I follow the procedure for USB Recovery
BUt, I've read this information on Xpenology
tutorial : in step 4 "WARNING you will loose ReadyNAS OS forever"
Source : https://theyeti74.wordpress.com/2014/03/12/turn-you-readynas-ultra-into-a-native-synology-nas/
So, I think it will be impossible to restore the NAS- Retired_MemberNov 12, 2018
...but you could possibly give the box back to the seller and ask for a for a full refund based on what you now found out.
- StephenBNov 12, 2018Guru - Experienced User
I've sent you a PM (private message) on this.
Hello Stephen,
I've seen your MP and this of MGM too ;-)
I'll send him a message later 'cause I'm not at home actually.
- Jul 15, 2018Retired_Member
