Freebird317
Nov 23, 2016Luminary
Reinstall OS?
I have setup Time Machine on my RN104. It was working at one point in time but now it has stopped. All it get is preparing disk... I have recreated both the time machine back job on my ReadyNas and M...
- Nov 25, 2016
I have it fixed. The problem turned out to be a know issue with my Mac. I forget the CVE but basically I move my keychain DIR from library to my desktop. Rebooted. That fixed it. Of cource I had to create keychain passwords. :)
Freebird317
Nov 24, 2016Luminary
Loganalyer
iStatNT
PHPSysinfo
AV
Freebird317
yes Ive bounced the nas :)
- Freebird317Nov 24, 2016Luminary
I dont mind reinstalling the OS on my nas if it might help. does it make sence to reinstall? i just dont want to go thru setting it backup, i work all day on windows servers.
ya you a pool man has the dirtiest pool on the street. ;)
- StephenBNov 24, 2016Guru - Experienced User
Do you have a backup of the data?
I doubt that a reinstall will help, but it likely won't hurt either. Maybe manually install 6.6.1?
tried that...just finished...no go. bbooo
- mdgm-ntgrNov 24, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- Freebird317Nov 25, 2016Luminary
- FramerVNov 26, 2016NETGEAR Employee Retired
Hi Freebird317,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
- Jul 15, 2018Retired_Member
