Deaf_Raiders1
Aug 08, 2012Aspirant
Release 4.1.9 - shares reverting to nobody/nogroup #19150263
Release 4.1.9 - shares reverting to nobody/nogroup case 19150263 I can't access my ReadyNAS Duo v1. I put it into Tech support for you of you to downgrade it to 4.1.8 and had a power cut the later ...
mdgm-ntgr
Aug 13, 2012NETGEAR Employee Retired
Is your NAS picking up an IP now? If so can you try to install this add-on?: http://www.readynas.com/download/addons/4.1/Enable_Remote_Access_1.0.bin
If it works let support know the 5-digit ID that you get.
