danielgroz
Aug 29, 2013Aspirant
Remote backup onto NAS - connection issues
Hi all, I'm trying to back up a folder on my work computer onto my home NAS. My workplace has a static IP and have also set my work computer with a static LAN IP. I have set up port forwarding to d...
Sep 10, 2013Guru - Experienced User
For remote file access, you can use readynas remote or ftp fairly easily. If you go with ftp, use the encrypted ftps variant in the client, as that is secure (and the data sounds sensitive).
Backup can also be done with remote, though you might also look into crashplan (or similar) cloud backup for disaster recovery. Crashplan is just for backup though, it is not suitable for simply consolidating storage.
