nappa
May 13, 2013Aspirant
Remote shutdown on OS 6?
Is there a way to do a remote shutdown on OS 6? I found this for older versions: viewtopic.php?p=94750 but nothing for OS 6.
chirpa
May 13, 2013Luminary
Easy way to sniff XML for ReadyNAS via Google Chrome browser...
Open Dashboard, then in Chrome choose Tools>Developer Tools. Click on the Network tab in that Inspector. It will show you all network calls. Run the command you want, and find the related dbbroker call for it. You can then 'Copy to curl' in the right-click menu to get a working curl call for it.
