glennamos
Jul 15, 2017Aspirant
Remote streaming of media files to IOS devices
I have a ReadyNAS 104. 1. I can stream my media files via local wifi and Ethernet seamlessly to: IPhone IPads WD media streamer Xbox using a combination of Plex and infuse App. 2. What I ho...
glennamos
New to that aspect, could you talk me through it?
- StephenBJul 16, 2017Guru - Experienced User
The default port that the plex server uses is 32400. The normal steps are
- reserve an IP address in your router for the plex server (likely your ReadyNAS)
- forward TCP port 32400 to that reserved address.
The details depend on your router model.
Once you've done that, the plex app should be able to play your media over the internet.
