glennamos
Jul 15, 2017Aspirant
Remote streaming of media files to IOS devices
I have a ReadyNAS 104. 1. I can stream my media files via local wifi and Ethernet seamlessly to: IPhone IPads WD media streamer Xbox using a combination of Plex and infuse App. 2. What I ho...
glennamos
Jul 17, 2017Aspirant
IP for NAS and port forwarding in the router are identical, router settings for HTTP and port ID of 32400 this reflects plex setting.
Also tried to add server manually in plex app advanced settings using IP and router setting but would not connect over LTE network.
I'm thinking with the router IP and port setting showing active in the firewall for port forwarding maybe this is a NAS issue restricting access to internet.
Jul 17, 2017Guru - Experienced User
Since you reserved the address in the router, the NAS should be using DHCP.
You can check internet connectivity by download the log zip, and looking in connman.log. You should see NTP time adjustments.
